Tuning question...
Username: Quig
Pittsburgh, Pa Us
Post Number: 186
ok first can anyone gime a website on wat Htz means, describing the differnt soundings, and also freqencies too... and real quick can someone describe what 30-40 hz sounds like, what Htz is good for sq, sp, spl. thanks.
Username: Quig
Pittsburgh, Pa Us
Post Number: 187
bump
Username: Dannyboyy
Peterborough, NH USA
Post Number: 233
36+ is more spl 30-35 is sql and 29 and below is sq... but its different for some woofers but i would use that as a basic tool.
try this if you are building an enclosure
http://www.subwoofertools.com/forum/ported-box.asp?Ew=34&Eh=15&Dia=6&Xmax=24&Vd= .18&NumW=2&Vb=4&Fb=28&Qts=&Vas=&Fs=&CE=0
Username: Quig
Pittsburgh, Pa Us
Post Number: 192
k so waht about cuft space, the more= ? the less =? vented box=spl? sq?
reasaon i want to know about this is becuz im gettign redy to build dual 12" box vented ( i think) i want to be hear from far away so use vented?
Username: Quig
Pittsburgh, Pa Us
Post Number: 197
bump?
Username: Kaerfpl
Spencerport, NY USA
Post Number: 82
What subwoofers are you going to be using?
Username: Quig
Pittsburgh, Pa Us
Post Number: 200
well im plannin on gettin 2 type rs and i would want a dual vented 12 enclousre for spl.
Username: Quig
Pittsburgh, Pa Us
Post Number: 202
bump.
Username: Mikechec9
Post Number: 2404
http://www.dak.com/reviews/Tutorial_frequencies.cfm
http://www.ethanwiner.com/equalizers.html
http://www.bcpl.net/~musicman/freqchrt.htm
