Wiring component & coaxical speakers in different ohm loads
Username: Longbluesquid
Post Number: 14
Is this possible? and is it just like wiring subs in parallel or series?
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 1061
Wiring options have no effect on the speaker since it is done prior to the crossover.
DO NOT CHANGE WIRING CONFIGURATION PAST THE CROSSOVER ! It will change the crossover point, and sound terrible.
The only setback to wiring components other than straight, is that you will get mono.:-(
