Matt Kitzis....i have some questions for you
Username: Blainew
Post Number: 1278
1-what kind of car do you have
2- did you get a new alternator for the 2500d
3-if u didnt get a new alt. are you using a capacitor
4- what are the fuses on the 2500d and what wires are you using
im thinking about tgetting one
Username: Blainew
Post Number: 1281
bump
Username: Usask8er1
Appleton, Wisconsin USA
Post Number: 302
I got a 1996 Audi A6 Quattro
Stock Alternator 120Amp Bosch
Also i have a capacitor but i still feel i need to upgrade the Alt to like a 200amp. The amp works fine for what I need it to do but if I were going for straight spl and had the amp turned up more id definatly get a new alt no question about it.
For fuses I have a 250 amp right before the amp. Gets the job done.
Username: Blainew
Post Number: 1283
alright thanks.....and would you reccomend the amp??
Username: Usask8er1
Post Number: 303
Yeah for sure, i love it I never had any problem with it and its just all around amazing. Im thinking of getting another one for my other car.
Username: Blainew
Post Number: 1284
alright thanks alot...... im buying one in a month
Username: Usask8er1
Post Number: 304
what are you going to power with it, if i may ask?
Username: Blainew
Post Number: 1285
2 alpine type X's
or 2 of the pioneer premier 1000 watt RMS subs
