Pictures of my Beauty / RF limited edition Power 1000 / Only 2500 MADE
Username: Suleman36
Maryland U.S.A.
Post Number: 3938
Number of Channels 5
Rated Power Front/Rear Channels
50 W x 4 @ 4 Ohms RMS
100 W x 4 @ 2 Ohms RMS
150 W x 4 @ 1 Ohm RMS
200 x 2 W @ 4 Ohms Bridged Mono
300 x 2 W @ 2 Ohms Bridged Mono
Sub Channel
300 W x 1 @ 4 Ohms RMS
600 W x 1 @ 2 Ohms RMS
800 W x 1 @ 1 Ohms
Total Power 1400 Watts
Bridgeable Yes (front/rear)
Crossover Controls Front Channels
High-Pass (HP): 40-400Hz 12db or 24db/Octave Linkwitz-Riley
Low-Pass (LP): 40-400Hz 12db or 24db/Octave Linkwitz-Riley
10x crossover switch
Rear Channels
Sub Channel
Low-Pass (LP): 32-250Hz 24db/Octave Linkwitz-Riley
Infrasonic filter: 28Hz fixed
Tone Controls Bass: 0dB to +18dB @ 35-75Hz (sub channel)
Signal Input Low level: 3 RCA pair
Signal Input Switch: 2/4/5
Signal Output n/a
Power Input Connector Block
Power Wire Gauge 1/0 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 12 AWG
Heat Sink Type Cast aluminum
Cooling Fan Cooled
Remote Controls ParaPunch Bass EQ (included with cable)
Visual Indicators Power On
Thermal
Output Short Circuit
Fan On 3 Stage Termal
Low B+ Voltage (below 11VDC)
5-channel Level Monitors
Circuit Topology Class Front/Rear Channels
Class A/B
Sub Channel
Class BD
Frequency Response Front/Rear Channels
20Hz to 20kHz +/- 0.5 dB
Sub Channel
20Hz to 250Hz +/- 3dB
Dimensions 2.6 x 12.8 x 23 (in)
6.6 x 32.51 x 58.42 (cm)
Weight 13 Lbs.
(5.9 Kg.)
or
FOR MORE INFO:
http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=8&family_id=27&item_id=101755&locale=en_US
Username: B101
Queen City, NC USA
Post Number: 3442
NICE!
what will it be pushing?
Username: Suleman36
Maryland U.S.A.
Post Number: 3940
Not sure yet. Im open to ideas :-)
In my other car i have a Arc Audio XXK-1500 thats going to be pushing 2 10w6v2's
This amp will be for my next install or other ride.
I was thinking the RL-p 12 whould be nice for this amp to push at 800 x 1 @ 1 ohm / birth sheet has it for over 900 rms.
Not sure which car this will be going in so im not sure about other speakers but im open to sub suggestions.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 898
nice man
Username: Justababyboy
Philly, PA
Post Number: 53
Hey Mo....when you gonna get back to me about the specifics on where to get sumthin like this
Username: Suleman36
Maryland U.S.A.
Post Number: 3941
Thanks guys
Marty you need to PM me and i will PM you back.
Username: Nikoncd
Post Number: 61
Awesome... only jealousy over here. haha. hope you find something to push soon, love to see the install!
Philly, PA
Post Number: 54
Yea I know I PM'd you last time....I guess you didn't get it for some odd reason
Username: Believe
Illinois
Post Number: 157
run 2 twelves @2ohm with a 15 in the middle runnin @ 2ohm
or run three woofers and three tweeters in each door up front @ 2ohm.. and a sub
i think the 50x4 sucks as much as 100x4
but three pair of components in the front would be great! (wire two in series and add the 3rd by parrallel)
im gonna get the hifonics xxchaos to run my 12w7 until i can afford the arc audio 2300se
then im gonna use the hifonics to power two pairs of components on each side -!-
oh.. you could also put three components in the door and use the sub channel to power an 8inch sub in the doors also
then run something serious in the trunk
that would really be impressive.. those 8 inch subs in the front doors would pull the bass up front better then any time alignment ..xxx.. seriously superb when you have bass up front and in the trunk
its like a home theater and having a sub on each side of the room vs just one sub on one side of the room
Username: Suleman36
Maryland U.S.A.
Post Number: 3942
Im going to go with a Sound Splinter Rl-p 12 ported at 2.0 cuft net @ 28hz
Username: Sploosh56
Ohio
Post Number: 1373
rockford fosgate really needs to make quality products again like that amp
Username: Suleman36
Maryland U.S.A.
Post Number: 3945
Yeah i agree. There power amps and up are quality amps. The Punch amps are solid aswell.
Username: B101
Queen City, NC USA
Post Number: 3451
all the RF stuff is underated....
MO I like that box tune... :-O
Username: Suleman36
Maryland U.S.A.
Post Number: 3946
lol, B i knew you that whould make you happy
