Orion 2500d....how many amps of fuses
Username: Blainew
Post Number: 1276
how many amps does this amp draw????
Username: Blainew
Post Number: 1277
anyone....?
Username: Andysd03
Post Number: 241
prob around 150 to 200 amps my kicker 2500.1 is about 150amps so its prob around that
Username: Extrmndor3
Chicago, Ill Us
Post Number: 1236
nope 200 amps will be fine from your batterie to your amp
Username: Northomaha
Post Number: 139
i have a 250 amp fuse from my battery to my two hifonics bx1500d amps
Username: Blainew
Post Number: 1279
is that with your stock alternator?
Username: B101
Queen City, NC USA
Post Number: 3448
these amps dont have ANY fuses...
your supposed to fuse within 18ft of the pwr wire to the battery positive.. with a ANL type fuse...
on my 2 runs of 0ga wires, I have 2 300a ANL fuses.. to protect the wires...
the amps can pull over 200 amps @ 1ohm.. and about 260 amps @ .5 ohms EACH...
depends on where your gain is set...
Username: Scott_debaker
Pittsburgh, P.A. U.S.A.
Post Number: 581
i gota 250 anl big fuse an 18ft of power wire an its fine amps r sweet an power a pair of type rs @ 1ohm damn
Username: Blainew
Post Number: 1282
i guess what my question is....is how many amps does a 2500d pull from the alternator??
and can u get by with a stock alt. and a cap
and also, lets just say the amp pulls 200 amps...isnt that at full power...???
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 7933
wow...read glasswolf's website
