Car audio in home????
audio
Is there any way to hook up car subs and a car amp in your house. If so can someone help me.
Any help would be highly appreciated.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2739
no good way, no.
it can be done, but the results pretty much suck, and it's expensive.
better off just going to eBay and buying a used home subwoofer for $150
audio
yeah thats what I thought. Would a home reveiver running at 8 ohms work with a jl w0. On the jl website it said the w0 can be run at either 4 or 8 ohms. Will this work.
thanks
JL makes a 8ohm W0 and a 4 ohm w0 get a 8ohm and it will work. go to this site and look at the JL W0-8 they have them at a pretty good price.
http://www.acaraudio.com/default.php?cPath=24_48&sort=2a&page=3
audio
thanks alot for your help
