New member Username: Skythefly13Post Number: 2 Registered: Jun-06 | I am looking for a good MTX setup (mono amp and 1 sub) that will really hit hard in my 4runner, possibly under $450-500. Any help is appreciated! |
Bronze Member Username: B_sonPost Number: 61 Registered: Apr-06 | http://www.sonicelectronix.com/item_2239.html + http://www.sonicelectronix.com/item_6882.html ur welcome homes |
Bronze Member Username: Gojoecrewchief1Post Number: 12 Registered: Jun-06 | should try to look for those on ebay they will be cheaper yet or look for a similar setup |
Bronze Member Username: Gojoecrewchief1Post Number: 13 Registered: Jun-06 | 105 for the sub 177 for the amp on the ebay just same as alex stated |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 883 Registered: Dec-05 | why mtx? |
New member Username: Skythefly13Post Number: 8 Registered: Jun-06 | I just heard they were the best for subs, I guess not though ...Sounds like thats not how it really is, so any other ideas? |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 897 Registered: Dec-05 | mtx has some good things, subs from 7500 and up and their mono amps, but they're too expensive for what they do. At least you asked, that's good. |
Silver Member Username: JkidderSpring hill, Florida Usa Post Number: 209 Registered: Nov-05 | 15" ascendant audio arsenal n' a phoenix gold xenon 600.1 or octane 800 watt.. xenon is a nicer amp tho... u can get both on ebay for cheap n' the arsenal is only like 250 i think???? |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 1920 Registered: Oct-05 | yea. i wouldnt go mtx |
