Can you hook up 2 4 ohm dvc subs and 1 2 ohm dvc sub to the same amp?
Username: Rick_ross
Post Number: 202
can you hook up 2 4 ohm dvc subs and 1 2 ohm dvc sub to the same 1 channel amp. If you can what would be the total ohms if you hook them all up in parallel?
Username: Rick_ross
Post Number: 203
does anyone know?
Username: Alias747
MN
Post Number: 1093
Your not going to want to do that anyway. Trust me, it won't turn out good. Always use only exact same subs in multiple sub applications.
Username: Extrmndor3
Chicago, Ill Us
Post Number: 1173
its gonna make your amp go into protect mode or is gonna fry ur amp
Username: Camaro823
British Colu... Canada
Post Number: 394
Already asked this question but more opinions help, how bout 2 different amps for 2 of the same subs. Not completley different both are alpine and about a 50w difference.
