Power handling
do you guys think that a fosgate 800@2 is a lil too much for two 12 alpine type r's? I think that the amp is putting out 400 rms to each sub, but the sub claims to handle only 300 rms. will this wattage difference be important?
Username: Pat_l
Tucson, AZ USA
Post Number: 49
You can never have enough watts!
Username: Sploosh56
If it's clean power it's shouldn't realy be a problem. Just don't crank your stereo all the way up
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2716
I've seen type R subs take at least 600 watts each without much trouble as long as it's a decent amplifier and gains are set properly.
