JL Slash or JL E-series Amps
Username: Panache
Brenham, TX US
Post Number: 56
Ok guys, what is the diff b/t the JL Slash and the JL E's? Im new to this stuff!
joe718
I believe the slash amps are mono 1 channels and the E series are multi channel...
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2885
no.
the slash series hae regulated power supplies and output stages.
the E series do not.
Username: Panache
Brenham, TX US
Post Number: 58
What do you mean by regulated power supplies Mr Glass?
Username: Glasswolf
Post Number: 2893
in simple terms, with a regulated power supply, any input voltage from 9 to 16 volts (about) comes out 12 volts on the other side.
it's "stablized" so more voltage doesn't equal more power, but this also helps avoid clipping if voltage drops.
