Silver Member Username: SplmonsterNowhere, OH USA Post Number: 273 Registered: May-06 | i have a friend on a grand prix specific site that has a treo delaer near him, he has about 700 to spend on sub/amp combo whatd be a good choice, thanks ps no 18's, 15" max |
Gold Member Username: DrivingrecklessNear tampa, Florida United state... Post Number: 1046 Registered: Apr-06 | i would go for the 12" ssx..at my dealer they are 629...and if powered with atleast 2000rms they will pound harder then he has ever known |
Silver Member Username: SplmonsterNowhere, OH USA Post Number: 276 Registered: May-06 | well i was thinkng a 15 ssi, so he doesnt have to upgrade electrical, he said the ssi 15 is $445, and is 750wrms, do think that would be okay? and maybe an amp suggestion?? because he has 700 to spend on sub/amp combo not just for the sub |
Gold Member Username: DrivingrecklessNear tampa, Florida United state... Post Number: 1047 Registered: Apr-06 | u could buy the pg x1200.1 the kicker 750.1 the jbl gto1201 B's amplifier the maxxsonics 1000d but yea the treo ssi i would be a good choice if he's really into sound quality plus they do get hella loud |
Silver Member Username: SplmonsterNowhere, OH USA Post Number: 278 Registered: May-06 | ssi is sq? is the tsx or tsi more spl geared??? |
Gold Member Username: DrivingrecklessNear tampa, Florida United state... Post Number: 1049 Registered: Apr-06 | well ive noticed from my tsx is tht it is sql oriented=....but as for the tsi i cannot say for i have never heard one |
Silver Member Username: SplmonsterNowhere, OH USA Post Number: 280 Registered: May-06 | so which of those 3 u think would be the best spl wise? |
Silver Member Username: SplmonsterNowhere, OH USA Post Number: 285 Registered: May-06 | anyone know? |
Gold Member Username: B101Queen City, NC USA Post Number: 3350 Registered: Sep-05 | TSX will edge on the SPL if powered correctly. SSI will have most SQ out of all TSI is just a BABY SSI... SQ based.. |
Gold Member Username: B101Queen City, NC USA Post Number: 3351 Registered: Sep-05 | but get him a SSI 12 or 15 with a 1000D or a TSX 15 with the 3" vc with a 1000D flip a quater... ![]() |
Silver Member Username: SkiesCourtenay, British Colu... Canada Post Number: 163 Registered: Aug-05 | is the SSX SQ oriented too? |
Gold Member Username: JakeyplaysbassSt. Louis, MO Post Number: 1165 Registered: Jul-05 | SSX sql/spl depending on the box. i dont really like the TSi they sound good but there pretty beginner. go with an SSi 12 or 15 and ED nine.1. it should be right around what you want to spend. |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3805 Registered: Aug-05 | i would get an SSi.![]() less power required, and you know it will sound good. ![]() |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 1236 Registered: Jan-06 | If he had more money I would go with a set of SSI 10.22. I have a pair that I got stuck with (impulse buy) but I have been very happy stuck with these twins for sure, lol. I have them a little underpowered and they slam, very surprised and they fit right under the GP's back deck with lots of trunk room! I use lots of bass boost and haven't heard a peep from them. The only problem is they hit hard so they bring out extra rattles that I haven't found using 15's so I am getting some Malibu N pink lemonade and do some rattle finding tonight, lmfao...Polo.. ![]() |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 3808 Registered: Aug-05 | ^^^^^.....LMAO!!!!! i am not sure who Malibu N Pink Lemonade are....but that was funny. ![]() |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 1237 Registered: Jan-06 | Dude try it! 3:1 ratio, lol. It's a drink fool, haaaaaaa.. ![]() |
Silver Member Username: SplmonsterNowhere, OH USA Post Number: 290 Registered: May-06 | any other amp suggestions for the a 15' ssi??? |
Gold Member Username: DrivingrecklessNear tampa, Florida United state... Post Number: 1057 Registered: Apr-06 | i would reccomend a jl 1000/1, zapco ref750.2, jbl bp1200.1, kicker kx1200(i think thts wut it is called)....oh and wut would be perfect for it i cant believe i forgot a orion 1200D |
Gold Member Username: B101Queen City, NC USA Post Number: 3352 Registered: Sep-05 | MM2000d https://www.ecoustics.com/electronics/forum/car-audio/239842.html |
