Trying to out play punsh stage 2
Username: Kenny_hammond
Post Number: 163
i want to out play 2 stage 2 punch 10's will these subs do the trick? this is the box i am using http://caraudiofactory.com/19942001-dodge-extended-p-75.html here are the subs http://www.soundsplinter.com/rlp12_premium_series_12_inch_DIY_subwoofer_informat ion.html or are there any better setups to use
Username: Rovin
Trinidad & T...
Post Number: 8192
P2 r only 200wrms each so it wont take much 2 beat them out provided a good install is done ....
Post Number: 164
dude these subs pound out some good clean notes it is a comp between me and my buddy i ghave 2 12w3's do u think that they will sound good in that setup and what size amp should i get
