I have a question...
Username: Billay
Should I buy 2 10" alpine type e's in a vented plexi glass box and a 750 watt amp for $300
or should I buy 1 15" mtx sub and the 750 watt amp for $300?
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 956
wut is the 750 watt amp????
Username: Extrmndor3
Chicago, Ill Us
Post Number: 1087
if ur talkin about mtx 8500 and up it wil be worth it type suxx so bad dude do not buiy them buy 2 10 assasins and some alpine amp
Username: Billay
Im not sure what the amp is, but should I buy them used, or should I save up and buy new?
Post Number: 957
i would buy new......i only buy used if its a REALLY good deal
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 256
ha theres another logan...
Username: Dandandan
Brisbane, Queensland Australia
Post Number: 109
LETS GATHER AROUND AND ANSWER THE QUESTION
Username: Lexuscoop
Pheonix, Arizona USA
Post Number: 860
i wouldn't go with the type E, your better off with the MTX.. what modle is the MTX?
Username: Gangstaplayer
Gangstaville chicago
Post Number: 142
depends what you listen to
