2 12" alpine type r's
Username: Dsmith07
Post Number: 11
what amp would you guys reccomend for 2 12" alpine type r's in a vented box im trying to stay in the 300-350 budget thanks u guys
Username: Robman0079
Post Number: 55
get this
http://cgi.ebay.com/2006-AUDIOBAHN-A16000V-NEW-DESIGN-MONO-INTAKE-AMP_W0QQitemZ9 737330690QQcategoryZ64571QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
This will bump the hell out of em.
Username: Dsmith07
Post Number: 15
no picture or link is coming up for me
Username: Rick_ross
Post Number: 59
thats not a good amp for them anyway are they 2 ohm or 4 ohm dvc?
Username: Juliob
Santo DomingoDominican Re...
Post Number: 704
if they're dual 4 ohm get an amp that puts out 1000-1200 rms at 1 ohm, check hifonics if you're in budget or go with mb quart raa 1000, if they're dual 2 ohm get alpiner mrd 1005, don't buy the audiobahn stated above cuz you'll be underpowering them
Username: Rick_ross
Post Number: 60
hifonics bx1605d
Username: Djbeanpole
Naptown, Indiana USA
Post Number: 207
kicker kx1200.1
Username: Killemall
Edmonton, Alberta Canada
How many decibles should two type r's push if powered properly in a proper ported box?
Username: Adddisorder
West palm, Florida
Post Number: 367
or get an mb quart raa1000, as far as dbs i have no idea im sure someone here does though
Username: Andysd03
Post Number: 178
get the orion2500d
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=426
and 2 12" type R should hit close to 150
Username: Scott_debaker
Pittsburgh, P.A. U.S.A.
Post Number: 495
ill b buyin 2 12 type rs an i already gota orion 2500d an a 8.4 cuft box hehe
Username: Rovin
Trinidad & T...
Post Number: 8149
SPD i hope ur buying the 4ohms dvc model so u can run it @ 4ohms coz that amp does 1200wrms @ 4ohms....
Post Number: 499
ya the 4ohm dvc but runnin them @ 2500w @ 1ohm
Username: B101
Queen City, NC USA
Post Number: 3173
a good mean machine 1000d. 2k6 model
does about 1100-1200 @ 1ohm...
https://www.ecoustics.com/electronics/forum/car-audio/239842.html
I can get you down to 300$ for the 1000d! join the group buy!
Username: Rovin
Trinidad & T...
Post Number: 8156
^^^ if were me id get the extra power of the 1400D model .
SPD - well i hope u know what ur doing cause i got that amp but not brave enough 2 run it with 2500wrms ...
Username: Denali_on_22s
Maryville, TN Us
Post Number: 32
Im looking to buy a kicker COmpVX 15 and thinking about pushing it with a hifonics TX1505D... do yall think that will be a pretty good setup? How loud do you think it with get with the hifonics amp runnin 1000 watts RMS at 2 ohms
Post Number: 500
mark from tcab i think he had his on the 2 type rs @ 0.5ohms right now i got that amp on 1700W@ 2ohs on the 2 10s an wow thay pound an flex the hell outa the back window ill have a video by the 28th
