Amp for s8L7 and Alpine components?
Username: 05taco
Missouri
I am definitely a Newb! Not only to the forum, but car audio in general. I have searched and learned a little, but have a long way to go. So.....please be gentle.....and dumb it down for me.
I am looking for amp recommendations for a single kicker 8" L7 and a set of Alpine SPX-177R components. I know the sub is not the best SQ sub out there. The space I have is limited and I already have the box for my truck. I do not have the sub yet, so I will have the option of either the 2ohm or 4ohm.
Do the # of watts to the sub have any bearing on SQ with this sub?
I have considered the Alpine MRV-F345(enough RMS?) or the MRV-F545(too much RMS?). What do you guys recommend?
Thanks for the help.
Username: Rick_ross
Post Number: 76
do you want one amp or two amps?
you should get a mono 1 channel amp that is 500 rms x 1 for the sub and a 2 channel that is 75 rms x 2 for the components
Username: 05taco
Missouri
I can go with two amps....if that would be best.
What amps do you recommend? I do not need the top end. I want quality at a decent price.
Username: Rick_ross
Post Number: 77
http://www.crutchfield.com/S-qRslVTWzqTe/cgi-bin/ProdView.asp?g=100&I=236T282&se arch=mtx+amp for the speakers
http://www.crutchfield.com/S-qRslVTWzqTe/cgi-bin/ProdView.asp?g=100&I=236T421D&s earch=mtx+amp for the sub if you get 4 ohm dvc and run it at 2 ohms
Username: Rick_ross
Post Number: 78
this would be better for your sub than the one i just put up http://www.crutchfield.com/S-FPIcapJvDGm/cgi-bin/ProdView.asp?g=100&I=206ZX4001& search=kicker+amp
Username: B_son
Post Number: 56
don't buy from crutch too expensive get the sub and amp from here
http://www.woofersetc.com/
Username: B_son
Post Number: 57
too make it easy
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=276<<<amp
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2086<<sub
