Possible Amp decision
Username: Kenkenni
Hi again. I havs my mind set on this particular
amplifier; http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4257.
What are your thoughts. Once again I am going to
power two Audiobahn ALUM10N 1600 watt io" subs
dual 6 ohm voice coils with a recommended RMS of
800 watts. Or can someone recommend a particular
amplifier for my set up.
Kenn.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 7665
that amp will do no good, i posted in ur other thread what u needed, max watts are pointless, only rms matters
Username: Snopro4ever
Post Number: 68
buy an audiobahn a8000t or two, their liek 140 shipped on eaby and they actaully put out 800wrms and 1600 peak, they are the best budget amp u can get for the price.
Username: Tjmutlow
Post Number: 2296
you need an amp that is 1ohm stable, the 2 subs you have wire down to 1.5, or buy another dual 6 sub and wire down to 1ohm......
