Portable DVD Player Question????
Username: Extremesound1
Coventry, RI United states
Post Number: 188
how can i hook up my portable dvd player to my radio... so i can have the sound coming out of the speakers of my car.
there is a front and rear output. but if i put one in the front as example sound only comes out the front..
i want it to come out all the speakers how do i do that.
i have a 7700 pioneer deck if that helps
Username: Jmloughrey
Farmington, CT
Post Number: 1558
As long as you have an AUX input you should be alright.
Get some RCA Y-adapters and go to town.
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 971
For a simple hook up, go ahead and do what Jeff said. Just get RCA Y splitters and split the signal so that you may have all four speakers running.
But,
I think there may be a little more to it than that.
DVD recordings have surround sound recordings. You may need a system that is capable of adapting from a 5.1, 6.1, or 7.1 etc... to a regfular front and rear audio setup. This is probably where your problem lies.
Take for instance a home DVD surround sound setup. If you scroll through your audio options you will see that you may select just the front speakers to play or surround. When you play a DVD recorded in surround sound mode, most of the sound will be coming from the main front L/R speakers only. Occasionally you will get sound coming from your rear L/R speakers, but only if there is a something that has been recorded coming from behind the camera so to speak (kinda like a car passing by).
Username: Mateo
Post Number: 107
theres a seperate forum for this stuff.....
Post Number: 189
alright thanx guys
and i came here because it is the fatest replying one,, everybody comes here.
Post Number: 190
im confused, i looked at the y adapters. i need 4 males and 2 females i cant find that look!!!
Orangevale, Ca. USA
Post Number: 980
Just get two sets of 2 males to 1 female.
Here is an inexpensive set of 2 males to one female;
http://www.americanhomeoutlet.com/index.php?main_page=product_info&currency=USD&products_id=101168
Orangevale, Ca. USA
Post Number: 981
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=240-125
