Need help putting my system together...
Username: Superroofer04
Darien, CT United States
Post Number: 7
I am in the process of building my own subwoofer enclosure. I'm at the point where I need to figure out how I am going to wire it, and to what. I have 3 10" 600 watt rms Audiobahn AW100vs, but no idea where to go from here. I know theyre 4 ohms, and in the manual that came with them it said i can run them at many different ohm's so im very confused. If someone can help me find an amp thats reasonably priced, or tell me what I need in an amp to power them, as well as help with wiring id really appreciate it. Thanks.
Username: Rovin
Trinidad & T...
Post Number: 8022
use this guide & see what works best with ur subs .....
http://www.the12volt.com/caraudio/woofer_configurations.asp
Username: Tweeker
Post Number: 154
you need a 1500-1800rms amp then we can see how you can wire your subs best for the amp. dont go cheap on the amp like the subs.
Post Number: 8
would a BOSS GT1500D 1500 WATT CLASS D MONO AMPLIFIER do the job?
Post Number: 9
or a HiFonics Brutus BXi1606D 1600 Watt Super D-Class Mono Amp?
Username: Dustin3
Tigard, Or U.S.
Post Number: 1423
well if their each dual 4 ohm sub then ur best bet is to wire them to a 2.6 ohm load (or 2, but will sacrifice power) or a 6 ohm load. the hifoncs is 1400 @ 1ohm. i dont like boss amps
