Kicker kx2500.1 2ohm sub or 1ohm
Username: Pike110
Post Number: 80
which would be better to get a dvc 2ohm model sub or dvc 1ohm model? I am running it with a kicker kx2500.1
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 7341
since the kx2500.1 is only 2ohm stable, get a 4ohm sub
Username: Pike110
Post Number: 81
If I were to get a 2ohm or 1ohm. How many watts would the sub be getting? Would it only be using half the power?
Username: Ctmike
Ct.
Post Number: 735
if ran at 2ohm, you'll see 2500w, probably more cause kicker underrates their amps. that is if your charging system can handle it.
Username: Pike110
Post Number: 82
So, if I were to buy a 1ohm or 2ohm subwoofer would it not be able to be wired to its optimal? Or do I have to get a 4ohm model? The kind of sub i'm looking at only come in 1 or 2 ohm.
Username: Tjmutlow
Post Number: 2153
what sub, not many come in 1ohm and also just 1 sub or 2....
Username: Pike110
Post Number: 83
Its for a friend. Its two solo x 18's and he is going to run a kx2500.1 to each sub. I know how stupid the install is and he is throwing money down the toilet, but he wanted me to ask because he has heard different things about which sub to get.
Username: Ctmike
Ct.
Post Number: 736
get 4ohm dvc subs
Username: Tjmutlow
Post Number: 2154
not enough power tom run them......
