Help plz
Username: Dtresatti2005
Pittsburgh, Pa
Post Number: 18
ok ive been running a crappy profile amp to my two type r 12's dual voice coil 4 ohm and they ahve been hitting pretty hard but i kno i can get alot more out of them i just havent had the money.... now i saved up $3oo. so i need a amp that will push those ryt for 300 shipped . i was lookin at the kicker amps like the 1200.1 but i cant really decide ne feedback will be appriceated... thank you
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2284
the KX1200.1 would be a nice choice. good quality amp, underrated, plenty for thoes Type R's. not sure on price or wheather you can get one for $300 shipped though.
Orion would be another good choice. the 1200D. not really over rated, but still a good amp and prob a lil cheaper if you can't get a KX1200.1 for your budget.
Pittsburgh, Pa
Post Number: 19
hey thanks thats the two i was lookin at... thnaks for ur feedback... ne body else have ne other amps that i shuld look at for around 300 shipped...
Username: Rick_ross
Post Number: 37
directed 1100d or 1500d and you could probly get it for about 200
