Bronze Member Username: Snopro4everPost Number: 53 Registered: Apr-06 | is this a decent amp to get for 100.00 used? will it put out any kind of good wattage? also is it enough to power to alpine type r? |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 1408 Registered: Oct-05 | show a link |
Bronze Member Username: Snopro4everPost Number: 55 Registered: Apr-06 | im getting it from a friend, but i think it is soemthign liek this one. http://cgi.ebay.com/NEW-Pioneer-GM-D510M-CLASS-D-MONO-AMPLIFIER-1000W_W0QQitemZ9 728506099QQcategoryZ18797QQssPageNameZWD1VQQrdZ1QQcmdZViewItem |
Bronze Member Username: Snopro4everPost Number: 56 Registered: Apr-06 | btw its (2) alpine type r |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 1414 Registered: Oct-05 | Continuous Power: (4 ohm) 300W x 1 Continuous Power: (2 ohm) 600W x 1 not enought power if u are talkin bout the 12" type-r's which are 500 rms i believe. you need an amp that does TRUE 1000 rms @ 1 ohm. or 2 ohm. |
Bronze Member Username: Snopro4everPost Number: 58 Registered: Apr-06 | what about for my kappas, which are 350w rms a piece |
