Big ? about buying an amp
Username: Snopro4ever
Post Number: 51
i have 2 infinity kappa perfect 12.1 svc, and i want to run them to peak, they are 350w rms and 1400w peak.
would i be better off buyign a cheaper amp that puts out 700 rms and then like 1600peak or buy this jbl which is like 650 rms. does this jbl have more wattage peak or how does it work, i can get the jbl for like 100.00 brand new.
http://www.jbl.com/car/products/product_detail.aspx?prod=GTO601.1%20II&cat=AMP&s er=GTS&language=ENG&country=US&region=USA
Username: Tjmutlow
Post Number: 2145
that jbl is not enough power,it is rated at 14.4 volts depending on your cars voltage system in it. you need something around 800-100ow at 2ohm load, or try the infinity 1211a or a kicker zx-1000, or alpine mrd-1000.
Username: Dustin3
Tigard, Or U.S.
Post Number: 1402
if u want cheap amp thats puts out 800, go with audiobahn a8000t
