Gold Member Username: GoatinOhio U.S.A Post Number: 1206 Registered: Jan-06 | I am looking in to getting one but I always thought they were no good. I am just looking for any good or bad input Thanks, |
Gold Member Username: GoatinOhio U.S.A Post Number: 1261 Registered: Jan-06 | http://www.ikesound.com/product-product_id/3775 This is the one in question ^^.lol |
Silver Member Username: Usask8er1Appleton, Wisconsin USA Post Number: 168 Registered: Jun-05 | My budd had a Ma audio amp and it seemed to hold up fine he had it for a year untill he switched to a kicker 2500.1 but untill then it powered ok nothing special but it worked. As far as that amp ive never seen it in action but I doubt its .5 ohm stable, most of the best amps out there arnt .5 ohm stable or even close to it. I bet it over heats right away |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 655 Registered: Dec-05 | i doubt of the RMS power, because most of MA audio amps are rated at 17 volts, no system will put that amount. Their high end stuff is powerful |
