Profile AP2000?
Username: Cawb
Post Number: 25
Would this be a better amp to power my CVRs than a A8000T
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 7346
he!! no
Username: Cawb
Post Number: 26
lol, so you think the audiobahn 8000T would be my best buy for 200$ under
Post Number: 7347
unless u can get like a Hifonics 1200 or 1500, then yes
Username: Reef
Post Number: 229
hey chauncey should i make my make box one chamber so both cvrs share the same chamber and have a slot port or have each sub have its own chamber and have 1 port per chamber?
Post Number: 7354
have each sub in its own chamber
Post Number: 7358
Username: Reef
Post Number: 231
and have a round port per chamber, i hope i can make a box that is 4.50 cu ft, to fit in my camaro, is it true that if your subs ported recommnend Cubic ft is bewteen ex 1.75 and 2.25 you usually want to pix the max cubic ft? or does it matter
