Rockford Fosgate T20001bd & Rockford Fosgate Power T8004
Username: Boo71886
Post Number: 22
I want to use these amps to power the following system
CD/video head unit-Pioneer AVH-P6800DVD
EQ- Pioneer DEQ9200
Sun Visor Monitors- 7inch monitors
Components- (front) JL Audio XR570-CSi (Back) JL Audio XR570-CSi
Subs- JL Audio CVS210RG-W6v2
Capacitor- Lanzar LQ24CAP
Xbox(if it can fit)
Are those amps good? Would they be able to power all this? Is that mono sub over kill for the subs? The mono amp is Rockford Fosgate T20001bd and the multi channel is Rockford Fosgate Power T8004.
Username: Dustin3
Tigard, Or U.S.
Post Number: 1350
they are good amps, but u would be overpowering ur subs by alot. for 2 w6's get a jl 1000/1. the rms on each sub i beleive is 500. so 500 x 2 subs = 1000 watts rms. 2000 is doubling the max rms which is not good. at the most i would get a 1200 watts amp
Username: Boo71886
Post Number: 23
i thought they was rated at 800 rms each making it 1600
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 819
all toghether its 800 rms continouis...for the 2 10's it says 400rms each.....so that big of an amp aint the best idea......if u had all that stuff your car ditch the capacitor, and buy an ho alt....so u can runn all that stuff at 1 time...and not burn up everything...yes and for 2 w6's a jl 1000 would be perfect...and a 300/4 or 450/4...u would have a full jl system....the install would be nice
Username: Boo71886
Post Number: 24
I just saw the MTX T9500 12' subs, do you think i should go with 2 MTX T9512, 2 JL W6v2, or 2 W7's? Which ever i go with will be 12 inch, i listen to alot of hip hop, rap, r&b, some rock, reggie, etc. My only quark with the W7's is ive heard it tends to skip notes, y dad has 2 w3's 12' in the trunk with a zapco amp for the subs n rockford fosgate amp for the jl channel speakers and its one of the best systems ive heard, thats y im highly considering JL Audio.
Username: Dustin3
Tigard, Or U.S.
Post Number: 1357
i like thr w6's. clean and loud. the 9500 series can match the w7 pretty well but the w7 still be have better sq and get a lil louder.
Username: Gage
Post Number: 293
do you have an ho alt.
Username: Gage
Post Number: 294
