New member Username: Madgame112Grand Rapids, Michigan Usa Post Number: 2 Registered: May-06 | MY lil brother just bought these subs:4 HIFONICS GOLIATH XX3215 15" 6400w SUBWOOFER. And he needs to know if they will fix in the trunk of his 92 oldsmobile cutlass supreme. And if so what is a great amp that is compatible with these subs. And also what is a good box to buy ported, sealed, or bandpass. Thanks in advance for the help. here are the specs: * 15" Goliath series subwoofer * 6,400 watts peak output * 3,200 watts RMS output * Integrated One-Piece Spider- Tinsel Lead Design * Chrome Cast-Aluminum Speaker Frame * 1.4" Extra-Wide Polyester Surround * 360y Vented Voice-Coil Assembly * Back-Plate Bumped for Long Excursions * Nickel Plated Push & Insert Terminals * Metal Dust Caps Prevent Hi-SPL Cave-In * Dual-Layer Conex Spider- Assembly * Fs = 39.63Hz * Qts = 0.37 * Vas = 17 Liters * Xmax = 25mm * SPL = 98.29 dB @ 2.83v * Quad 2-Ohm Voice-Coils * Can be run @ 1/2-Ohm, 1-Ohm, 2-Ohm, 4-Ohm, or 8-Ohm * 18-3/4lb./300oz. Triple-Stack Magnet Assembly * 4-inch Bi-Flair Black Aluminum Voice-Coils * High-Strength Composite Silver & Fiber Glass Cone |
Silver Member Username: JohammbassCork, Cork Ireland Post Number: 217 Registered: May-06 | FS 39.63hz and that's on a 15" driver, total crap Do you have a tank to put them in? Do you have a little nuclear power plant installed in your car, because you will need some serious alternator(s)? Over 12000W RMS, is everything OK with you people? That Cutlass will blow up You could get a couple of these ampd right here if you got that much money to spend on it: http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=589 This amp can kill you, no kidding. |
