Xmax ?
Username: Doom
What is xmax?
Username: Van_man
Boston, MA
Post Number: 403
"Xmax:
By definition it is the peak linear travel of a driver. If you measure the distance that the voice coil can travel in the gap (in one direction) while the number of turns in the gap doesn't change, you have the Xmax. If you go past this point, the actual windings in the voice coil start to leave the gap. The diagram below shows the voice coil at its maximum travel at point of max linear travel and just past its point of max linear travel"
Excert from http://www.bcae1.com/
Username: Doom
Is there a way I can figure out the xmax of my 05 12" alpine R?
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 1213
looking it the specs.. i think its 19 or so
Username: Doom
I dont have them and cant find on google.
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 817
for those who r still interested an couldnt find the pic of the Voice coil Upload
Username: Troy81
Tavernier, Fl Us
Post Number: 277
so thats "bottaming out" and hurting the sub?
Username: Mike_anthes
Canton, SD USA
Post Number: 337
bottoming out is when the sub mechanically can't throw any further right???
Username: Believe
Illinois
Post Number: 92
its when it throws back too hard
