Amp wiring question
Username: Theweasel
Post Number: 196
i just ordered my 15" arsenal but i can't afford an amp to power it yet. i have got a 2 channel sony 2200gtx amp ( i know, laugh away) as my only current amp. can i bridge this to my arsenal or can i just run one channel to it? sub is 4 ohm dvc.
Username: Nnnnick_b
Weddington, Nc Usa
Post Number: 751
Hook up one voice coil to each channel on that amp. you will give each coil 200 watts rms @ 4 ohms. If you bridge the amp and wire the sub in parallel then the impendence will be to low and the amp will go into protection or fry(its sony)
