Help choosing new hu
Username: Hondarider
Glidden, Iowa U.S.
Post Number: 215
Which one do you like the best and why?
1.http://www.crutchfield.com/cgi-bin/ProdView.asp?g=300&id=detailed_info&i=130DEHP680
2.http://www.crutchfield.com/cgi-bin/ProdView.asp?g=300&id=detailed_info&i=257KDG820
3.http://www.crutchfield.com/cgi-bin/ProdView.asp?g=300&id=detailed_info&i=500CDA9853
4.http://www.crutchfield.com/cgi-bin/Prodview.asp?c=3&g=300&I=113KDCX590&s=0&cc=01
Username: Basshead86
Google is your Friend, FL
Post Number: 3515
i would go with number 1 or 3 personally.
i am not a fan of JVC or Kenwood. they aren't that great of a quality HU.
Username: Hobbskc
Post Number: 16
I just bought a new Kenwood HU. It's just like the #4 link but the model below.
I like it alot.
I have no complaints yet, but heard two downfalls are:
1)Can't see anything in direct sunlight
2)The control knob is a bit touchy but exceptable
The best feature IMO is the USB port coming out of the back. I had mine wired into my glovebox. Pretty neat.
There's my two cents.
Peace,
Hobbs
Username: Johammbass
Cork, Cork Ireland
Post Number: 162
Pioneer or Alpine would be ones to go with
