Like
Inside of sub
Username: Superroofer04
Darien, CT United States
Im building a sub box with plexiglass...my question is what can I put on the inside in terms of carpeting that wont absorb the sound?
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1045
im guessing your talking about covering the wood so that it looks good?
most audio shops spray dynamat dynashield on it. its a black spary that works similar to the paint on dynamat. i would check it out.
Username: Basshead86
Google is your Friend, FL
Post Number: 3494
you could just spray paint the inside....don't put any carpet on the inside of your box.:-)
Facebook
Shop Related Deals
Directory
