My AMP shuts off when i raise the volume PLEASE HELP
Username: Thejoester101
Post Number: 10
These are the full specs of the speakers:
XS-LD125P5 sony explodes
# P5 Rigid Aluminum Deposition Cone Design
# Dual 4-Layer Voice Coils
# Durable Foamed Rubber Surround with Stroke Stabilizers
# Double Damper Suspension
# Dual Stacked Magnets
# Gold-Plated Binding Posts
# Rear Voice Coil Vent with Vented Heat Sink
# Optimized for both Small Sealed and Ported Enclosures
# Mounting Depth: 5.88"
# Rec. Sealed Box Dims: 1.00 cu.ft.
# Rec. Ported Box Dims: 1.50 cu.ft.
# RMS Power Range : 125-500 Watts
# Peak Power Handling: 1400 Watts
# High Frequency Response: 2500 Hz
# Low Frequency response: 18 Hz
# Impedance: 4 Ohm
specs for amp:
sony XM-2002GTR
# 200 watts RMS x 2 at 4 ohms
# 250 watts RMS x 2 at 2 ohms
# 500 watts RMS x 1 at 4 ohms (4-ohm stable in bridged mode)
# Low-pass crossover (50-300 Hz, 12 dB/octave)
# Variable bass boost (0-10 dB at 40 Hz)
# MOSFET outputs and power supply
# Speaker-level inputs with signal sensing for automatic turn-on
# Preamp inputs and outputs
# Fuse rating: 40A x 2
# CEA-2006 compliant
# Wiring and hardware not included with amplifier
# Dimensions (W x H x D): 15-7/8" x 2-1/4" x 10-7/8"
Please help me with this. I have a left and a right input into the amp. I did a series connection with the two subwoofers and im going into 1 output jack out of 2 jacks on the amp. I previously tried a parellel and it didn't work, its doin the same thing now but it has better thump than the parellel way. But what its doing now is shutting off at a certain volume still. Can you please help me.
Username: Snopro4ever
Post Number: 26
TURN YOUR GAIN DOWN, YOU ARE PROBABLY PUTTING THE AMP INTO PROTECT... you are most likly forcing a suare wvae through your speakers, causing your amp to go into protect mode
Username: Alias747
MN
Post Number: 902
Ok man, the only way that you can hook those subs up to that amp is going to have to be each sub to it's own channel. You won't be getting the most out of your amp but thats how it goes sometimes. Let me know if you understand, or if need more help.
Username: Alias747
MN
Post Number: 903
BTW, there is absolutely no need to make 3 different threads for the same problem. Please do not do that anymore, there is to much clutter as it is.
Post Number: 11
I am sorry about posting it again. #1 i did a parellel connection hooking a subwoofer up to its own channel and it was doing the same thing. #2 how do you change your gain, i only have 3 knobs on the amp, filter, low boost and level? Can you please help again.
Post Number: 30
level is your gain i believe, you most liekly have it on max, because you want your speakers to eb the loudest they can be. but you need to turn in down some, .
the test you shoudl do is turn your HU all the way up or pretty lose and keep turning your level down until it doesnt cut out anymore..
Username: Tjmutlow
Post Number: 2103
the ohm load is not correct, you have to run 1 sub per channel
Post Number: 12
ok thanks for the help, I appreciate it.
