HPF
Username: Bretzy1990
Springfield, Il U.S.
Post Number: 27
ok my question is that on my amp its hpf is 35-250htz and on my headunit is a pioneer and is able to go from 50-125htz. lets just say if i were to set my hpf on my amp to 80htz would it let my headunit set it at 100htz and play at that level. what should i set it on so i can control through my headunit?
Username: Goatin
Ohio U.S.A
Post Number: 1054
You need to set your amp higher than your hu because your hu will not override your amp.
Damn Sub Forum's down I answered your question right before it went .lol
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2119
whatever you set the HU to, set the amp's so they don't interfere. like, i have my HPF on my HU set at 100Hz and the one on the amp set to 80-90Db. that way, they don't interfere. i always use the HU crossovers as the main ones and the amp crossovers as back up.
Post Number: 28
sweet thanks
