Another 2500d question.
Username: Titanbk
Mansfield, CT USA
Post Number: 107
I realize it has 2 power supplies. Now should I run 1 0 gauge cable into a distrbution block then 2 4 guages cables to the amp? Or should I just run 2 4 gauge cables from the battery to the amp? Whats your opinion on the matter. I am running a 200 amp alternator built by nate and 2 optima yellow tops in case you needed to know.
Username: Rovin
Trinidad & T...
Post Number: 7977
i'd pick 1 0 gauge cable into a distrbution block then 2 4 guages cables to the amp - thats exactly what i intend 2 do with mine soon
nice guide - http://www.the12volt.com/info/recwirsz.asp ....
