A8000t
Username: Cawb
Post Number: 10
Would this be a good amp to power my CVRs
Username: Tjmutlow
Post Number: 2117
not unless they are dual 2ohm speakers, that amps max power is at 2ohms,if dual 4 ohms then running it at 1ohm will most likely burn it out or if you ran it at 4ohms maybe 400w total if lucky.....
Username: Reef
Post Number: 149
i was just wondering if that is a decent amp i know i half to match the ohms and every thing, thanks
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 7173
The A8000T would be if u had 2 dvc 2ohm
The A8002T would be if u had 2 dvc 4ohm
Both of which would be great for ur subs
Username: Reef
Post Number: 154
ok thanks chauncey, i got a question, how come when i put a cd in it makes sounds out of my subs and every time i turn the song it makes noise out of my subs?
Post Number: 7191
Bad or Cheap Hu' or RCA's, more then likely
Username: Reef
Post Number: 155
Its a piooner, my friend told me to get 2 eclipse subs instead of CVRs, should i just stay with CVRs or are eclipse better?
Username: Thomas_g
NM
Post Number: 667
Damn it Devin go 2 bed u got skool 2marrow!jk lol
