Which Amp???
Username: Dlenz4437
Post Number: 27
I just got 2 12" w3v2's at 300 rms and i dont know which amp to get. I was thinkin of
http://mobile.jlaudio.com/products_amps.php?amp_id=252
http://www.alpine-usa.com/en/products/product.php?model=MRD-M1005
http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=6 &family_id=20&item_id=27698&locale=en_US
i dont know, i think the rockford fosgate would be the best but its alot of money. please help out!?!?
Username: Nnnnick_b
Weddington, Nc Usa
Post Number: 705
What is the VC configuration on your w3's
Username: Juliob
Santo DomingoDominican Re...
Post Number: 570
PG 600.1
Username: Dlenz4437
Post Number: 28
dual 4 ohm
Username: Emdawg12345
Post Number: 34
get this its easily in ur budget http://www.rotteneggs.com/?refid=182315
Username: Juliob
Post Number: 586
orion 600d, directed 750d, pg 600.1....
Username: Dlenz4437
Post Number: 29
tommy i didnt really see anything in that link but yeah i think i'll go with that orion. But isnt it ok to get a bigger amp so you dont run it on max all the time?
Username: James1115
Ct
Post Number: 5790
no! you should never run it on max unleas your RCA output voltage matches up with the max setting on your amp.
Username: Pinkymccray
Durham, North Carolina USA
I need help! I have a 92 Honda Accord Wagon and I"m completely redoing everything. I have 2 12" Cerwin Vega V-max Subs, 2 Infinity Ref. 5 1/4's in hatch, 2 Infinity Ref. componet speakers 6 1/2's in front, a kenwood cd player (for now), and I have not a clue what kind of amp. to get. I was told to get something to push the 12's. I don't have a set limit on how much to spend, but I would like to eat and pay rent. Price range maybe $200-$400.
Thanks
Username: Dlenz4437
Post Number: 30
how do you find out your rca voltage, and by rca output voltage do you mean the voltage coming from your head unit to your amp thru the rca's?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6887
Jackie, what are ur voice coil configs on those subs???
And David, it should be in ur hu manual
North Carolina USA
Chauncey, the Voice coil configs are 180*C. It says ultra high temperature. Am I on the right path with what I have so far?
Post Number: 6900
lol, Jackie, are the subs dual voice coil, single voice coil, and are they 4ohm, 2ohm, etc..
Username: Rovin
Trinidad & T...
Post Number: 7727
"""the Voice coil configs are 180*C""" - wtf ! ....LOL
Username: Juliob
Post Number: 608
nice joke
North Carolina USA
Chauncey, they are dual 4ohm.
North Carolina USA
Still looking for help with finding an amp. Can someone please help me?
Username: Ctmike
Ct.
Post Number: 473
whats the rms on your subs? and budget?
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1731
jackie anything around 1200wrms@1ohm would work, look into kx1200.1 orion1200d just to name a few.
