Alternator ?
Username: Northomaha
Post Number: 43
I bought a 200 amp alternator from nate at excessive amperage and i am wondering if that will let my two 1500d hifonics amps operate at full potential?
Username: Rovin
Trinidad & T...
Post Number: 7723
http://www.wickedcases.com/caraudio/charging.html
Username: Jcash
Post Number: 38
nope you need at least a 250 amp lt or a 300 amp alt. that two hundred will work though if you dont have much cash.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6899
u will be fine...trust me
Username: Juliob
Santo DomingoDominican Re...
Post Number: 609
you can buy some batteries in case of, so there's no problem
Post Number: 44
Yea i have one dual cycle marine battery under the hood because the marine max would not fit so when i get the money i think im gonna put a marine max in the back instead. I know B was runnin a similar alternator to his subs before he got his 300 amp and i dont think he had a problem
