Good 800 watt rms amp?
Username: Nruzicka
Wauconda, Illionis U.S.A
Post Number: 25
what is a good 800 watt rms amp to power 2 cvr 12's?
thanks
Username: Rovin
Trinidad & T...
Post Number: 7698
http://www.onlinecarstereo.com/CarAudio/ProductReview.aspx?ProductID=14965
Username: Emdawg12345
Post Number: 36
http://www.rotteneggs.com/?refid=182315 this is wayy cheaper
Username: Nruzicka
Post Number: 26
i cant get that link to work????
Username: John_wash
Nashville, Tennessee
Post Number: 250
very nice amp Rovin but not tryin to knock your idea but i was gonna suggest this amp if he was on a budget.
http://www.caraudiodeals.com/product_info.php?products_id=66&gclid=CODoheHV5IQCF Q8wNAodHh0gmQ
Username: Goatin
Ohio U.S.A
Post Number: 997
ignore Tommy or emdawg he is retarded.
Rovin pointed out a nice amp that will give you a bit of headroom.
MTX makes a great 800rms amp I am shure it costs a bit more than the mb but if you want a really good 800 watt amp check those out.
Username: James1115
Ct
Post Number: 5789
I have a orion HCCA 250g4 which does 800x1 @ 1ohm at 12volts if you are interested.
Username: Thomas_g
NM
Post Number: 403
I have a 268 lanzar powering my cvr's it puts out pretty good power for being that it was only $150 with shipping. A little over 900rms.
Wayyyyyyyy cheaper, budget amp. I love mine.
Username: Rovin
Trinidad & T...
Post Number: 7718
well 4 those of u all who may not know i actually own that MB amp & u may notice my review of it in that same link ...
Username: Thomas_g
NM
Post Number: 427
Yup. Rovin i like that amp.
Rovin From Trinidad , West Indies
I paid $299 shipped for mine from CField a few mths ago & i just love this amp cause of its simplistic uniform exterior design & straight forward performance . I have mine pushing 2 12" Alpine 1242D type R subs & its brilliant ! Not too crazy on its allan key type terminals but its the only fault i can find . If i knew it was so cheap here i would have bought 2 ! & 2 Alpine type X subs to go with it ! .....
Like ur animated banana too, lol.
