Possible system
Username: Hockeyknight
Post Number: 90
ok this is what i think im gunna get. let me know what u think about it good or bad. also what would be a good box? i dont have all that much room but let me know.
1 12" cvx
http://cgi.ebay.com/2006-KICKER-COMPVX-12-CVX-12-SUBWOOFER-DUAL-2-OHM_W0QQitemZ9 718247631QQcategoryZ39777QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
1 mb quart
http://www.onlinecarstereo.com/CarAudio/ProductReview.aspx?ProductID=14965
Username: Rovin
Trinidad & T...
Post Number: 7646
didnt we went through this same deal last night ....
Username: Ctmike
Ct.
Post Number: 382
^^^thinking the same thing. ported box about 2cu.ft. tuned to about 38-40hz should work.
Post Number: 91
idk it might have been my brother lookin for me. today he just showed me the cvx ant mb . sorry
Username: Rovin
Trinidad & T...
Post Number: 7647
o i c
u never know who's on the other side of ur monitor
well anyway it was ur name & we did recommend ur options u posted ......
Username: Graphix1
Santa Rosa Heights, Arima Trinidad & T...
Post Number: 894
check 3ne
Post Number: 92
how bout a bandpass box. the only reason i say this is because the box is small and i need space. plus iv heard its the best way to get good bass if u are limited in space
http://cgi.ebay.com/12-inch-CAR-BAND-PASS-SUBWOOFER-SUB-WOOFER-SPEAKER-BOX_W0QQi temZ9720077819QQcategoryZ50568QQrdZ1QQcmdZViewItem
Username: Redliner
Wilmington, Ma
Post Number: 1708
if u dnt care about having your system sound like one note then fine it will make it i believe 9 db's louder or seomthing like that but it also kills sq dratsically
Username: Mtite_dabeast
Post Number: 27
Wat is SQ?
Username: Young_james
Post Number: 1396
sound quality
Post Number: 93
but this box would be fine? sq dosnt really matter to me i just want it to pound
