Lanzar?
Username: Steve_collins
Post Number: 38
so i was looking at amps for alpine type r and i saw lanzar amps. are they anygood because they dont sound to bad.
Username: Ctmike
Ct.
Post Number: 371
very low end amps. what's your budget, and are you powering 1 or 2 subs?
Post Number: 39
well im powering 2 and i have about 200 to 250.
Username: Sw9152
Michigan
Post Number: 488
looks can be decieving... they are extremely overated. if you are looking for a cheap amp get the audiobahn a8000t because it will put out its rated power. just keep the boost and gain down because it will be overpowering your sub a little.
Username: Sw9152
Michigan
Post Number: 489
do you have the newer or older type r, what is the rms per sub and what ohm vc do they have.
Post Number: 40
they are the newer 1242d and they are the dual 4ohm
Post Number: 41
could i hook up both of my subs to that amp or is it a mono channel
Username: Sw9152
Michigan
Post Number: 493
the audiobahn would not work then. hifonics would be another brand to look into they are overated a little but are still good buget amps.
http://cgi.ebay.com/HIFONICS-BXi1606D-1600-WATT-MONO-CLASS-D-AMPLIFIER-NEW_W0QQi temZ9720452232QQcategoryZ18797QQrdZ1QQcmdZViewItem
or this would be good
http://cgi.ebay.com/HIFONICS-BX-1500D_W0QQitemZ9720919286QQcategoryZ18796QQrdZ1Q QcmdZViewItem
Username: Ctmike
Ct.
Post Number: 374
you can run both subs to that one amp.
Post Number: 42
so i can run both or cant and i if i can is it too little power and ill need more
Username: Sw9152
Michigan
Post Number: 497
if you get a mono amp you can run both subs off of it, but it has to be 1 ohm stable. generally you want a mono amp for powering subs.
Post Number: 43
ok so if i get that amp will i need 2 of them to max out the 2 type r or will that still not be enough for them.
Post Number: 44
will this amp fully power the 2 type r
http://cgi.ebay.com/HIFONICS-ZXi1006-ZXi-Zeus-2-Ch-Car-Audio-Amplifier-Amp_W0QQi temZ9718266314QQcategoryZ18796QQrdZ1QQcmdZViewItem
Post Number: 45
will this amp fully power the 2 subs
Post Number: 46
the HIFONICS ZXi1006 ZXi Zeus 2-Ch Car Audio Amplifier Amp
Username: Sw9152
Michigan
Post Number: 501
prolly would be underpowering them because hifonics overates their amps. i heard the amps will actually put out about 80% of their rated power. the mono 1200 one would prolly be all right.
Username: Sw9152
Michigan
Post Number: 502
http://cgi.ebay.com/HIFONICS-BXi1206D-Class-D-Mono-Amplifier-Amp-BXi-1206D_W0QQi temZ9720938365QQcategoryZ18797QQrdZ1QQcmdZViewItem
Post Number: 47
for both subs it will?
Username: Sw9152
Michigan
Post Number: 503
yes
Post Number: 48
thanks a lot can you show me a link to that amp
