Edead Question: Outside Car
Username: Shawnomak
Sask Canada
Post Number: 210
I found a rattle underneath my car i never noticed before because the back panel rattled too much. I did the inside of the spare tire hole, but it still rattles the bottom of the car. Can you put edead on the bottom? I know id have to spend alot of time getting the dust and dirt off before I do anything if its possible. I also want to get some expanding foam for other places. Good idea, or should I not paint edead under my car?
Username: Goatin
U.S.A
Post Number: 888
you can buy undercoating/soundproofing at autozone.I think that would be better.
Username: Rovin
Trinidad & T...
Post Number: 7614
rattling below ur car can mostly be muffler or gas tank , check ur rubber bushings .....
Username: Basshead86
Ocala, FL
Post Number: 3068
there is something like that underneath my rear bumper and i can not find it.....it can be pretty frustrating when you can hear it but you can't find it. lol
Username: Shawnomak
Sask Canada
Post Number: 211
Yeah Muddy.. Whats even worse is thinking you know what the rattle is, spend hours trying to fix it and find out thats not whats rattling. arg, I think im gonna quit, lol :-(
