How are diamond audio subs?
Username: Pelona
Perris, California USA
Post Number: 1356
how is this diamond audio sub? does it have good sq? spl? i liked it cuz its frequency response goes all the way down to 18hz so it must hit low
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2691
Username: Pelona
Post Number: 1362
Username: Eprussian07
Post Number: 100
never heard that sub in particular, but Diamond Audio has the green light in my eyes, never heard bad stuff from them...
Username: Pelona
Post Number: 1385
how would u compare that sub to a kicker cvx and an adire audio brahma?
which one of these 3 subs goes the lowest?
Username: 69_ohm_stable
Post Number: 18
I have been researching diamond for about 3 months now. I was gonna put three jl audio w3v3's in my car on my MTX 942 but there is a guy here who has been in car audio for over a decade and he swears to me that three D3's will sound and pound much better. The only reasons that I am gonna check them out is because he sales jl and diamond at his shop, and because for the price of one w3, I can buy three D3's
Username: Redliner
Wilmington, Ma
Post Number: 1647
i heard diamonds sound very nice but ive never heard any diamond's so dont take my word on it
Username: Alteraudiousa
Concord
Post Number: 720
the D9 I believe use the same stuff in the TDX sub they used to have and those were some of the best underrated subs out there. I believe ICIX used it in their woofer test and had it up there with the W7. The Kicker CVX is not even in the same class as the Brahma. I would say depending on enclosure that both the brahma and d9 will give you awesome lows and sound good doing so.
Username: Pelona
Post Number: 1390
so ur saying a brahma has better spl than a cvx?
Username: Pelona
Post Number: 1391
and better sq than a cvx?
Username: Basshead86
Ocala, FL
Post Number: 3080
i think a Brahma would have better sound quality than Kicker's whole line of subs:-)
Concord
Post Number: 724
I don't know why all the sudden I see kicker CVX or CVR popping up as a good sub. They are nothing special at all. CVR is a budget sub that does well if you pay less than 100$ per sub and the CVX is only a step up from that. They're not good at SQ and the SPl on them is only good when in a high tuned enclosure but then you miss out alot of music. No Kicker sub will compare to series for series with Adire and honestly a lot of online companies.
Username: Pelona
Post Number: 1394
thanx for that info.
i already knew the brahma sounded better than a cvx but i thought that they were about the same spl.
but wut i like is being able to hit low. ima get 1 15" rather than 2 12" to get lower not louder. the 15" cvx fs is 18hz. i think the 15" brahmas fs is 17hz or 18hz
Username: Winterfreshpimp
Chisago, MN America
Post Number: 205
you cant hear under 20, and if you listen to subs alot youve prolly lost som hearing on top of that.
Username: Pelona
Post Number: 1397
yea i know but u can still feel under 20hz. if a 20hz note in a song hits it usually still has some 30-40hz in it so u can still hear it but u feel it more
Concord
Post Number: 725
you know, specs are a good place to start but really don't show the actual performance of the sub. My Mag has a higher fs, 22hz, but goes much lower than the kicker does and the brahma and sounds better doing it.
Username: Pelona
Post Number: 1398
yea i know about that but its a good place to start.
like i dont think its true that the idmax goes all the way down to 10hz.
Username: Pelona
Post Number: 1400
even though its a 12"
Username: Pelona
Post Number: 1407
so does anyone know anything bout the diamond audio d9?
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 2108
will get plenty loud enough and sound great doing it .. i just think its priced a little high
Username: Pelona
Post Number: 1411
since alter says the mag gets lower than than the cvx and the brahma. then does the 15" d9 go lower than a 15" mag? the d9 fs is 18hz
Username: Pelona
Post Number: 1415
bump
