Bronze Member Username: Illwill577Post Number: 39 Registered: Jan-06 | i need help on deciding on a box. it will be for 2 kicker 15"s l7s. i want the most SPL possible i heard for spl go with ported. and how much space to give each sub. and what to tune the box to. |
Silver Member Username: Sw9152Michigan Post Number: 468 Registered: Feb-06 | definately go with ported if you are looking for spl. the manual that came with your kickers should give box size recommendations. |
Bronze Member Username: Illwill577Post Number: 41 Registered: Jan-06 | yeah it says Ported box volume 3.0-6.0 cubic feet ill prob do like 3.4 i have a 96 cadillac deville so i got some room to work with. but what should i tune it at? i want all spl |
Silver Member Username: Sw9152Michigan Post Number: 476 Registered: Feb-06 | i would tune it to around 40-42 Hz. |
Bronze Member Username: Illwill577Post Number: 42 Registered: Jan-06 | know any websites that custom build boxes |
Bronze Member Username: Illwill577Post Number: 45 Registered: Jan-06 | http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D9720214274%26&sspagename= STRK%3AMEWA%3AIT%26 any suggestions if i should go ahead and get this box. |
Silver Member Username: CtmikeCt. Post Number: 346 Registered: Feb-06 | http://www.thecaraudiobox.com/ heard there really good boxes but a little pricey |
Bronze Member Username: Illwill577Post Number: 46 Registered: Jan-06 | that box on ebay says its tuned and all just wondering if it is worth buying |
Bronze Member Username: KrazyjUSA Post Number: 45 Registered: Jan-06 | if you dont want to build a box you could by it and brace/strengthin it on the inside to reduce flex |
