Quick ?
Username: Dtresatti2005
Pittsburgh, Pa
Post Number: 17
Hey wats up guys i was serarching through ebay when i came across a Mdx Amp Has neone ever heard of these kind of amps.. and if they have then let me kno wat u think and if i should get one im trin to decide between a few amps for my alpine type r 12 4+4 dual voice coil subs. that mdx is one choice and there is also a orion if ne one has ne info on those to it would be great and thanks i kno there kinda cheap amps but im on a tight budget.. thanks again
Username: Mtite_dabeast
Post Number: 13
idk about MDX, but orion is supposed to be a good name.
Going by name brand iz just like reading a title of a book and saying you read it in itz entirety. Look into some wattage rms and peak for both amp(s) and sub(s).
Good Luck... Isaac.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 533
buy PG xenon 600.1 or jl 500/1 for your type r, never heard of mdx, might be MTX? just go safe, buy one of the two amps i listed
