Need a new amp, mines pzd...
Username: Tyler33
Post Number: 38
Hey guys I need a new amp. I am running 2 10 audiobahn 500 rms each 1000 max...so 1000 rms and 2000 peak. What amp do you suggest, looking to go the cheapest way. Also I wanna put some neon rings, can I hook them up to the amp, or should I get something so it doesn't kill my battery or amp? Also should I get a capacitor, does it make a difference? Any help would be greatl appreciated, thanks.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6724
Audioburn A8000T or A8002T depends on ur subs vc configs
http://wickedcases.com/caraudio/capacitors.html
http://wickedcases.com/caraudio/charging.html
Username: Mtite_dabeast
Post Number: 22
I'd go with the audiobahn A1300hct. Not the cheapest, but im sure you could find one for less than $200.
