Sound storm amp(don't know if its blown)
Username: Beeminis
Houston, Texas US
my amp will shut off but when i turn the car off then back on the amp will power back up but then shut off again after a few minutes. bad amp?? its a sound storm
Username: Dustin3
Tigard, Or U.S.
Post Number: 934
going into protection, check ur gain or level input on your amp and make sure it isnt set too high.
Username: Beeminis
Houston, Texas US
i have a switch to cut the amp on and off. you know so when i go to a ghetto area i just turn that amp off. so when the amp "goes into protection" i just turn the switch off then back on and it will work for a lil bit then will shut back off. I'm running 2 10in Rockford p2, i have the amp set up as bridged so both subs are actually run to one channel. could that cause this
Username: Dustin3
Tigard, Or U.S.
Post Number: 956
having ur subs bridged wouldnt cause this. unless its sony or sumthin. When i say "go into protection" it means when the amp is over working and getting to hot. does the amp feel hot when it turns off? like i said, check ur gain on the amp, and maybe check to see if you have ur subs wired correctly so its not presenting an ohm load that it cant take.
