What is better SPL or SQ?
Username: Don_beeski
Bourbonnais, IL Kankakee
Post Number: 51
Also what is the difference between SPL and SQ?
Username: Ctmike
Ct.
Post Number: 323
spl=sound pressure level
sq=sound quality
neithers better cause everyone is different. if you want just really loud bass but don't care to much how it sounds then spl is for you. if you want it to get loud but still sound great go for sq. best thing to try for is a system that gets really loud and still has great sound which is sql.
Post Number: 54
How do you mix the 2?
Username: Ctmike
Ct.
Post Number: 324
some subs are straight spl, others are sq, and some are more sql subs. what are you looking for? and budget?
Post Number: 55
I have 2 2006 kicker cvx's 12". What type of sub are these?
Username: Ctmike
Ct.
Post Number: 325
i'd say spl, kicker isn't really known for their sound quality.
Post Number: 56
How would I make these into sql?
Username: Ctmike
Ct.
Post Number: 326
some people might disagree, and i know i'm far from the smartest on this forum, but i don't honestly think kicker can really be much more than spl. the cvx's will definately sound better then the solobarics, but they still lack the sq of others, like jl or aa or others. but if you want it loud it'll definately be good for you just be sure to have really nice speakers in the front so as not to drown everything out with the bass. i'd recommend a really nice set of components and decent rear speakers and properly power them.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 530
you just can't convert a spl sub to a sq, you just can improve the sound by building a good box and depends on how you tune it
