HIGh level input
Username: Stnorris
Post Number: 14
what is the high level input thing on amps that looks like a small cube and how do you hook it up. And whats it for...?
sry. im a noob.
Username: Dustin3
Tigard, Or U.S.
Post Number: 935
Factory radios do not have dedicated outputs for amplifiers (preamp outputs). an amplifier with speaker-level inputs. these inputs enable you to tap into the factory speaker wires for a signal, so its a good idea to make sure ur amp has speaker level inputs if your radio doesnt have speakers level outputs.
so high level input = speaker level input :-)
Username: Stnorris
Post Number: 15
so does high level input work for factory radios in place of RCA cables or rca jacks in the head unit?
Username: Van_man
Boston, MA
Post Number: 96
Yes
