Wiring component set.
Username: Shortysetnies
Post Number: 44
I have a 5 channel amp that is 4 x 110-Watts + 300-Watts x 1-ch RMS @ 2-Ohms. I want to hook up 2 component sets on channel 1&2, one set in kick panels, and one in doors. The component speakers are 4 ohm, and I want to wire them down to 2 ohms. How will I do that and still use the crossovers? Thanks
Username: Tjmutlow
Post Number: 1931
on components the only thing that gets hooked to amp is the crossover, so with that being a 4ohm load, you run the fronts to channel 1 and the rears on 9kick0 to channel 2.just hook the crossovers +,- together for the front and same for the kick panels.
