5.25 components for f150
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 1989
maybe i will get more looks here since i got nothing in speaker section ... what are some good components for me to put up front ? they need to be 5.25 and under $300 . and i got 2 10'' alpine type e's on 600 watts if that helps
Post Number: 1991
http://sonicelectronix.com/cat_73.html
are any of these sets under $250 any good ?
Username: Redliner
Wilmington, Ma
Post Number: 1384
i would say no but then again i dont know anything about components so dont take my word for it all i know is i wouldnt buy them
Username: Killswitchjd
Post Number: 45
infnity reference 5 1/4" components are good...
my 2 cents
Post Number: 1992
http://sonicelectronix.com/item_1742.html
what about these
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1644
what are you gonna power them with.
Post Number: 1993
not sure yet ... gonna see what some good speakers are then get me an amp
Post Number: 1994
http://www.woofersetc.com/index.cfm?currentpage=3&fuseaction=category.display&ca tegory_id=39&sort=high
what about these ? pick me out a set from this lineup
Username: Cenus
Post Number: 1647
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1085 i hear good things abot cdt,
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1155 focal
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1150 focal
heres some ideas, im not an expert at componet speakers but i here good things about cdt and focal on here.
Post Number: 1995
i like these .. and im like you ive heard good things about them
Username: Jonathan_f
GA USA
Post Number: 5943
Focal Polyglass components aren't that great. Focals high end stuff is nice, low end stuff sucks.
I'd save my money just a touch more and get those PG Ti Elite components-they're built and designed by Morel. Excellent components.
Post Number: 1997
thanks johnathan .. what about boston ? do they have any sets nice under $300 ?
GA USA
Post Number: 5944
Boston sets are nice-the newer Pro50 components should suit you. I wouldn't go with anything lower from them personally, though. Bostons tend to have a characteristic sound the people either love or hate, if you have a nearby Tweeter, Hifi-Buys,or other subsidiary try to go listen to a set before you jump.
Others in that price range worth considering are JL XRs and the MB Quart Premiums.
Post Number: 1999
i figured the xr's would be nice .. but chad said he didnt like them .. but then again everyone has different tastes , i may love them
Post Number: 2001
i was wanting to go with some jl xr's and maybe 2 12'' w3v3's .. would that be a nice setup for a single cab truck >
Post Number: 2003
johnathan between the mb quarts and xr's which would be better ?
Los Angeles, CA USA
Post Number: 3731
casey if you want the xr's then i suggest you getting the 3 ways. i've heard the xr 3 ways and they sound much better and different then the xr 2 ways. that is if you know how to do a good job of installing. i wanted 3 ways one time and jonathan told me they are hard to setup so i would be better off with just the 2 way.
GA USA
Post Number: 5947
Vehicle dependant. 3 ways are more difficult to implement in certain vehicle types. Generally, if you can't/don't want to do kick panels, you'll probably do better with 2 ways. The XRs have a rather higher crossover frequency to the midrange from the midbass driver, for that reason you'll want to keep them close together. 3 ways are nicer if setup correctly, though.
Post Number: 2004
so if im going to put them in the doors 2 ways are better ?
Post Number: 2005
http://www.madisound.com/cgi-bin/index.cgi?cart_id=2502849.27618&pid=2129
someone suggested these to me .. ive never heard of them and they seem kinda cheap to me
GA USA
Post Number: 5948
I posted that for somebody a while back :-)
Vifa makes great raw drivers-it'd be every bit as good as stuff costing much more than that.
Post Number: 2006
so they would sound just as nice as some jl xr's ?
Post Number: 2010
anyone ?
