My amp is powering on with just the remote and ground wire in place???????????
Username: Car1
Post Number: 25
whats happening?! can anyone help
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1865
is the radio on?? the remote lead is what turns on and off the amp. so if its got power, the amp will be on.
Username: Car1
Post Number: 26
the actual power wire is not connected to the amp... and the power is on. does this mean my car is LIVE?
Stockbridge, GA USA
Post Number: 1875
that means the REM wire is "live"
do you get output from the amp without the power wire hooked up?? or just the LED's light up??
Username: Safe_cracker
Chicago, IL US
Post Number: 873
Either way you will end up blowing the fuse or circuit for the remote and if it is internal you have to disassemble your head unit to fix it, DON'T DO IT ANYMORE... :-)
Username: Car1
Post Number: 27
what can i do to solve the problem? shall i find and alternative place for the reomote wire? !!!!CONFUSED!!!!
Chicago, IL US
Post Number: 894
Shuttig the radio off should shut the remoted led off too. Shut your head unit off and check to see if there is till power, if there is then chances are either you have the wrong power wire (battery led) or there is someting wrong with your HU. The wire should probably be blue in color. Polo..
